Does Robot have support for ASME Codes ?
If not, will this be included in future versions?
Thank you,
Solved by Artur.Kosakowski. Go to Solution.
No, it doesn't. I'm sorry but we are not in the position to discuss any development plans on this forum.
In robot 2016, for Australia standard,it have AS1170-4 for earthquake but i didn't see AS1170-2 for Wind actions. is there any solution to apply wind actions? thanks
You may try to use the Wind Simulation tool or generate wind according to one of the implemented codes if acceptable. Otherwise you need to define the loads manually.
