Discussion Groups
Robot Structural Analysis
Athi_uk
Robot Steel Frame analysis
588 Views, 3 Replies
10-21-2011 02:33 AM
Recently I have done a steel frame analysis in Robot 2011 and Can you please answer the following questions:
1. what is the default connections in Robot among the beams or beams and columns in a 3D frame?
2. Is it a rigid or pinned connection?
3. If I apply a pinned-pinned release among the bars structure becomes unstable during the calculation, how can I solve this issue?
4. Do we need to apply pinned-pinned releases among the bars when we do a frame analysis?
Many thanks
James
Please use plain text.
Product Support
Rafal.Gaweda
Re: Robot Steel Frame analysis
10-21-2011 02:47 AM in reply to: Athi_uk
Hi
As a default all connections between bars are fixed.
In case of instabilities please upload model or contact me by Private Message
Rafal Gaweda
Athi_uk
10-21-2011 02:57 AM in reply to: Rafal.Gaweda
Hi Rafal,
Thanks for your reply and I have attached the model with this message.
James
Product Support
Rafal.Gaweda
10-21-2011 07:37 AM in reply to: Athi_uk
Generally - too many releases (wrongly applied, giving instabilities - in this case errors in model).
You can not release bars on pinned supports (-> the same dofs released twice).
My vision of this model attached: fixed supports with released columns, bracings ( 101to108 128to137) as  truss bars, Fixed-Pinned1 releases applied on structure, some relases changed to get rid of instabilities.
Rafal Gaweda
