Discussion Groups
Robot Structural Analysis
Product Support
jad.dellel
Accepted Solution
Robot Extensions Spreadsheet Calculator2012
4593 Views, 27 Replies
07-05-2011 01:32 AM
Question client:
"Bonjour,
J'ai bien réussi à installer la version 2012 de Robot Professionnal et à l'enregistrer, mais lorsque je lance le raccourci Robot Extensions - Spreadsheet Calculator 2012, j'obtiens une erreur et les applications sont impossibles à utiliser.
Que faire ?"
Customer's question:
" After RSA2012 installation, I tried to launch Robot Extensions- SPreadsheet Calculator 2012 but no applications were there, I can't use it, what I have to do? "
Jad DELLEL
Structural Engineering Support Autodesk, Inc.
Please use plain text.
Product Support
jad.dellel
Re: Robot Extensions Spreadsheet Calculator2012
07-05-2011 01:36 AM in reply to: jad.dellel
Bonjour,
Robot Extensions Spreadsheet Calculator2012 sera bientôt disponible pour les clients sous Souscription et téléchargeable depuis: http://subscription.autodesk.com/
Cordialement.
Robot Extensions Spreadsheet Calculator2012 will be downloadable, soon, for customers from: http://subscription.autodesk.com/
Jad DELLEL
Product Support
jad.dellel
Robot Extensions Spreadsheet Calculator2012 available now
07-07-2011 12:17 AM in reply to: jad.dellel
Bonjour,
Robot Extensions Spreadsheet Calculator2012 est disponible actuellement au téléchargement depuis le site de Souscription:
HI,
Robot Extensions Spreadsheet Calculator2012 is now available to download from
Jad DELLEL
*Expert Elite* | International Moderator
Romanich
Re: Robot Extensions Spreadsheet Calculator2012 available now
07-07-2011 06:52 AM in reply to: jad.dellel
Spreadsheet Calculator 2012 not working with Excel 2010 :smileysad:
Product Support
jad.dellel
07-07-2011 07:07 AM in reply to: Romanich
You need to have the 32bit version of office:
Jad DELLEL
Romanich
07-07-2011 11:36 AM in reply to: jad.dellel
Thanks Jad, I installed Excel x32bit version and saw this:
Active Contributor
07-08-2011 09:25 AM in reply to: jad.dellel
Hi
I am installing spread sheet calculator 2012 and I have windows 7 pro 64 bits+Microsft excel 2003.
the program runs but it is in demo mode.
Can I have a solution?  thank you.
Romanich
07-08-2011 11:05 AM in reply to: WASSIMSAID1507
Jad deleted post, but this tip there: download & install in trial mode Autodesk Quantity Takeoff 2012 32Bit. Reboot after install & try to run spreadsheet calculator. Thanks Jad for this hidden trip :smileyhappy:
Product Support
jad.dellel
07-11-2011 03:05 AM in reply to: Romanich
Well done Romanich,  you're a good follower of our RSA forum:smileyhappy:
I deleted the tip because I'm waiting for better solution and I'm not sure It will work for all the users
Jad DELLEL
Product Support
jad.dellel
07-15-2011 09:31 AM in reply to: jad.dellel
Hi All,
RSA/RSAPRO 2012 licensing error which appears on 64-bit operating systems inside RESC (former name ESOP), Experts and Apilogs can be cured by installing appropriate one of the following hotfixes:
License error hotfix for 64-bit OS - RSA,
License error hotfix for 64-bit OS - RSAPRO
Both are available on Autodesk Robot Structural Analysis Professional Services & Support page, under RSA 2012 and RSAPRO 2012 sections.
In few days Apilog, Expert, and RESC Content installations on Subscription will be supplied with this hotfix adding missing license element during installation.
I will inform you when exchanging subscription installations is finished.
Best regards,
Bonjour à tous,
Le problème de détection de licence rencontré sous RSA/RSAPRO2012 pour Spreadsheet Calculator, Expert et Apilog peut être corrigé en installant le "Hotfix" correspondant à votre version:
Cordialement.
Jad DELLEL
