Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot Continuous Foundation Design
1 REPLY 1
MRizea
1273 Views, 1 Reply
Hello all,
I curently designing a 2 story concrete building. I finished with the structure and now i would like to use Robot in calculating the foundations. Usualy i'm using manual calculations made in excel. But this time i would like to use Robot.
The soil seems to be very bad in the location of the site: conventional pressure of the soil 150kPa.
My thought is to do like this:
-remove all the fixed supports from my structure;
-model some reversed T concrete beams as the continuous foundations;
-assign elastic springs as support to the reversed T beams.
Now my questions are:
1. will Robot be able to dimension my concrete beams to the corect section ?
2. how will i determine the Kz coefficient ? does Robot now how to do that automaticaly ?
If you have any suggestions on how to do this, it will be appreciated.
Best regards,
MariusR.
1 REPLY 1
Artur.Kosakowski
in reply to: MRizea
Here you are.
Artur Kosakowski
Tags (1)
