Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Robot API - open and close project issues
6 REPLIES 6
1056 Views, 6 Replies
First question : I want to close a Robot project without saving using API code 'Robot.Project.Close', and without closing RSA application.
But nothing happens. I would like to go back to the starting window (the grey one with 'Projects' And 'New Project' Option). But the project is still opened and still appears in the Robot window. How can I do that ? Is there a kind of 'refresh' script to add ?
Second question : I open RSA through API using
Dim Robot As New RobotApplication
Robot.Visible = True
Robot.Window.Activate
I would like the RSA window to come to the front, above the window form which the API script is launched (Rhino&Grasshopper in my case - it could be Excel). It is not the case with my script, RSA just appears in the task bar, but does not become visible. How can I do that ?
Guillaume
6 REPLIES 6
Rafal.Gaweda
IN fact robot can not open moer than 1 project so Close option does not work as you think.
Close just sets Modified flag onto false and then while loading (openining new file) program will not ask you whether to save changes in previous file. So Close project then open file.
Rafal Gaweda
Rafal.Gaweda
After Robot.Visible = True it should be visible.
If you want it in foreground you have to use windows system functions, most likely using RobotApplication.Window.Handle
Rafal Gaweda
in reply to: Rafal.Gaweda
OK,
Thanks.
aruser
I would like to close the Project at the end of the sub after saving the changes.
"robot.project.close" seems nothing happens.
How can I close the Project or the application?
Thks
Artur.Kosakowski
in reply to: aruser
Try robot.Quit(IRobotQuitOption.I_QO_SAVE_CHANGES)
Artur Kosakowski
d.robin
in reply to: Artur.Kosakowski
hi,
is it possible to use the Close Menu with API to only close the file and not close robot ?
cause reopening Robot spend too much time
