Discussion Groups
Robot Structural Analysis
Active Contributor
RoboExploiter
Accepted Solution
Robot API for ARSA 2012 - error 429
786 Views, 12 Replies
11-03-2011 06:08 AM
How do I get my hands on a copy of  the latest Robot Object Model API? My excel VBA addin developed for ARSA 2010 is not finding an open version of ARSA 2012.
And can someone give me a list of changes between the two object modeslI so i don't need to find the errors in my code one at a time during execution?
Thanks.
Please use plain text.
Product Support
Re: Robot API for ARSA 2012
11-03-2011 08:40 AM in reply to: RoboExploiter
Active Contributor
RoboExploiter
11-03-2011 08:37 PM in reply to: Rafal.Gaweda
Rafal thanks.
I did what the thread suggested, unregistered both versions, reregistered 2012.  The Robot Object Model 2012 is now available as a reference.  However, now another error has occured:
Run-time error '429': ActiveX component can't create object
I assume this error is now occuring due to changes in my computers registry.  Any ideas?
Product Support
11-04-2011 01:32 AM in reply to: RoboExploiter
Check this :
http://support.microsoft.com/?kbid=184898
If it does not help please contact me by Private Message
Rafal Gaweda
Product Support
11-07-2011 03:14 AM in reply to: Rafal.Gaweda
Try also what is suggested in last post in this thread:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi...
Rafal Gaweda
Active Contributor
RoboExploiter
11-29-2011 01:24 AM in reply to: Rafal.Gaweda
Hi Guys,
Just thought I'd close out this post.  Adopting the solution provided in this post:
Resulted in "Run-time error '429': ActiveX component can't create object" during execution of my VBA code.
The reason for this error is most probably changes to the registry.
The only way my IT department and I managed to fix this error was to unistall and reinstall MS Office.  Its just a little worrying that following the provided solution would impact on other installed software.
Cheers.
Active Contributor
RoboExploiter
12-02-2011 01:41 AM in reply to: RoboExploiter
Hi Guys,
I'm reopening this post.  "Run-time error '429': ActiveX component can't create object" during execution of my VBA code, has not been resolved.
I've tried many methods to fix the registry and have reinstalled MS Office.
Please advise.
Product Support
12-02-2011 02:13 AM in reply to: RoboExploiter
Try this:
open VBA macro, go to references and uncheck Robot Object MOdeler reference, confirm closing.
Run macro, errors will be reported, stop macro
 go to references and add Robot Object MOdeler reference,
run macro.
If problem persists, run macro in debug mode (line by line) and make screen capture of line on which the problem occurs.
Rafal Gaweda
Active Contributor
RoboExploiter
12-04-2011 05:31 PM in reply to: Rafal.Gaweda
Hi Rafal,
Why would tuning the reference off and on solve the problem?
I've attached print screens.
If I hover over the command: "Robot.Project.IsActive" the floating information says <ActiveX component can't create object>.  I can't capture this with a print screen.
Please advise.
Product Support
12-05-2011 01:22 AM in reply to: RoboExploiter
replace:
Set Robot = CreateObject(“Robot.Application”)
by
Set Robot  = new RobotApplication
and report what happens
Rafal Gaweda
