Robot API for ARSA 2012 - error 429
12 REPLIES 12
Message 1 of 13
2439 Views, 12 Replies
How do I get my hands on a copy of  the latest Robot Object Model API? My excel VBA addin developed for ARSA 2010 is not finding an open version of ARSA 2012.
And can someone give me a list of changes between the two object modeslI so i don't need to find the errors in my code one at a time during execution?
Thanks.
12 REPLIES 12
Message 2 of 13
Rafal.Gaweda
Message 3 of 13
in reply to: Rafal.Gaweda
Rafal thanks.
I did what the thread suggested, unregistered both versions, reregistered 2012.  The Robot Object Model 2012 is now available as a reference.  However, now another error has occured:
Run-time error '429': ActiveX component can't create object
I assume this error is now occuring due to changes in my computers registry.  Any ideas?
Message 4 of 13
Rafal.Gaweda
Check this :
http://support.microsoft.com/?kbid=184898
If it does not help please contact me by Private Message
Rafal Gaweda
Message 5 of 13
Rafal.Gaweda
Try also what is suggested in last post in this thread:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/VBA-Excel-macro-for-any-object-geometry-modi...
Rafal Gaweda
Message 6 of 13
Hi Guys,
Just thought I'd close out this post.  Adopting the solution provided in this post:
Resulted in "Run-time error '429': ActiveX component can't create object" during execution of my VBA code.
The reason for this error is most probably changes to the registry.
The only way my IT department and I managed to fix this error was to unistall and reinstall MS Office.  Its just a little worrying that following the provided solution would impact on other installed software.
Cheers.
Tags (1)
Message 7 of 13
Hi Guys,
I'm reopening this post.  "Run-time error '429': ActiveX component can't create object" during execution of my VBA code, has not been resolved.
I've tried many methods to fix the registry and have reinstalled MS Office.
Please advise.
Message 8 of 13
Rafal.Gaweda
Try this:
open VBA macro, go to references and uncheck Robot Object MOdeler reference, confirm closing.
Run macro, errors will be reported, stop macro
 go to references and add Robot Object MOdeler reference,
run macro.
If problem persists, run macro in debug mode (line by line) and make screen capture of line on which the problem occurs.
Rafal Gaweda
Message 9 of 13
Hi Rafal,
Why would tuning the reference off and on solve the problem?
I've attached print screens.
If I hover over the command: "Robot.Project.IsActive" the floating information says <ActiveX component can't create object>.  I can't capture this with a print screen.
Please advise.
Message 10 of 13
Rafal.Gaweda
replace:
Set Robot = CreateObject(“Robot.Application”)
by
Set Robot  = new RobotApplication
and report what happens
Rafal Gaweda
Message 11 of 13
I tried that, and I get the same error.
Message 12 of 13
Rafal.Gaweda
The procedure described in last post of this thread :
helps but it must be done with ADMINISTRATOR RIGHTS
Rafal Gaweda
Message 13 of 13
Yes, don't know why it didn't work the first time as I had admin rights the first time as well.  Anyway, problem solved, thanks for your help.
