jonpople
589 Views, 6 Replies
Rigid Links
I am trying to model a slab with varying thickness, so I have offset one of the slabs and then used rigid links to attach the different areas of the slab. I have ticked all of the boxes in the Rigid Link Definition box.
Shouldn't this produce a continuous moment in the top of the slab where hogging occurs as the slab has only been thickened below and not on top? I do not understand how the rigid links transfer the moment.
Jon
6 REPLIES 6
jonpople
in reply to: jonpople
Artur.Kosakowski
Just  in the same way as very rigid bars with no releases at their ends.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
jonpople
in reply to: Artur.Kosakowski
Could you please comment on screenshot that I have posted. Why are the rigid links not creating a conituous moment?
Pawel.Pulak
If any in-plane membrane forces exist in the slabs and they are transferred through the rigid links the moments will not be continuous.
Considering the direction along the connection of panels with different thickness the discontimuity of the moment about this direction corresponds to membrane force perpendicular to this direction multiplied by the offset of panels (the length of rigid links).
If this post answers your question please click the "Accept as Solution" button. It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
jonpople
in reply to: Pawel.Pulak
So the moments that are produced are in fact perpendicular to the direction shown? X is showing Y and Y is showing X?
Pawel.Pulak
I was not referring directly to your screen capture because it was not showing MXX or MYY but Wood&Armer moments which are composed of MXX, MYY and MXY so it makes it even more complex.
But the discontinuity is justified even for moments turning around global X on your screen capture (depending on direction settings it can be MXX or MYY).
To show it in simpler way below is the bar analogy of this effect in case of 0.1m eccentricity (modelled by rigid link) between 2 bars:offset.png
Pawel Pulak
