Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Message 1 of 38
HoshangMustafa
1525 Views, 37 Replies
Ribbed slab
Hi
Artur wrote:
 My approach is to model a rectangular beam ('web') with no offset but with artificially increased moment of inertia (see theattached picture - IY of rectangular beam multiplied by ratio of IY of  T shape beam / IY of rectangular beam). This approach causes'increaseof bending in the beam (T shape beam effectwhile no axial forcse in the beam being generated.
Plz find the attached file. I applied this approach, but ARSA gave warnings & errors. Plz any guide.
37 REPLIES 37
Message 21 of 38
Hi Rafal
I asked whether ARSA can export a panel design to dxf with the panel thickness shown and the reinforcement shown on cross section of panel.
You posted:
Not possible.
You can create such view in ASD
I wonder if you can help me because I can't use ASD & the matter is very necessary.
With best regards
Message 22 of 38
Unfortunately to do that you have to draw reinforcement in ASD
Example : http://screencast.com/t/TgqoBkrhd
Rafal Gaweda
Message 23 of 38
Rafal.Gaweda
in reply to: Rafal.Gaweda
or import crosses (required reinforcement) and draw reinforcement in ASD
Example: http://screencast.com/t/fPMiieE5
Rafal Gaweda
Message 24 of 38
Hi
Thanx Rafal. Is it impossible for ARSA to have a section cut through panel to show reinforcement? ARSA can display the cross section of footings with the reinforcement. I hope ARSA can do it for panels.
Message 25 of 38
Unfortunately not possible for panels.
Rafal Gaweda
Message 26 of 38
Hi
Is the name of this software AutoCAD structural detailing?
Message 27 of 38
Yes
Rafal Gaweda
Message 28 of 38
Hi Rafal
Thank you
Message 29 of 38
Hi Rafal
Can ASD import required reinforcement from robot and draw reinforcement for these requirements the same way as robot design module is doing?
Can ASD import required reinforcement for beams, columns from robot? How?
Message 30 of 38
Yes.
No. Real reinforcement is imported to ASD.
Rafal Gaweda
Message 31 of 38
Hi
How can ASD file (dwg format) be edited in AutoCAD?
Message 32 of 38
Yes if you install ASD enablers.
You can find them on our www.
Rafal Gaweda
Message 33 of 38
Hi Rafal
What are ASD enablers?
How can I find them on www?
Message 34 of 38
Message 35 of 38
Hi Rafal
Thnk you very very much. I had downloaded the enabler and installed it. Forgive me, if you could show me how this is used to edit ASD drawings in autocad.
Message 36 of 38
Using ACAD commands.
Nothing will be automatically updated because it is not ASD.
Enabler allows ACAD to open properly \ to see properly ASD objects.
Rafal Gaweda
Message 37 of 38
Hi
Thank you very much. I'll try with it.
Message 38 of 38
Hi
1 -How can one import required reinforcement area for beams, columns from Robot to Autocad structural detailing (ASD)?
2- How can one adjoin elements (columns, beams, slabs) in Autocad structural detailing (ASD)?
