Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Tmlk89
219 Views, 3 Replies
Revit to Robot
I really have no clue what im doing wrong
i cant mesh Panels Correctly
and alot of instabilities occured even after i adjusted my revit model over and over with repairing the robot File
here's a link to The Revit File
http://www.4shared.com/zip/Pcs_Ui5u/latest_edition.html?
3 REPLIES 3
Tmlk89
in reply to: Rafal.Gaweda
i've already done most of those
checked the analytical model corrected it
corected the slabs beams walls everything
but there's just something im missing when it comes to robot and meshing and instabilities
Rafal.Gaweda
in reply to: Tmlk89
Sorry to say that but your model is so inaccurate.
But I manage to correct it my way in Robot:
- no kinematic links,
- no regular mesh,
- model generation tolerance set  1mm
- arc balcony redefined to fit @beams@ discretization
- columns should be defined from slab to slab
- supports should be defined at the column bottom nodes , not at additional nodes aside columns
Model: http://www.4shared.com/zip/jkL1X0Lv/Tmlk89_2013.html
Rafal Gaweda
