It is the first time that we are trying to transfer a model between Revit and Robot. At this moment in time we have Revit (with the Robot Extension) on one computer, and Robot on another computer. Do we need both programs on the same computer for this action to work or can a Revit file simply be saved as an RTD file?
Jon
Solved by Artur.Kosakowski. Go to Solution.
Yes, you need them both on the same computer as the part that 'creates' rtd file is 'inside' Robot.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
