I really have no clue what im doing wrong
i cant mesh Panels Correctly
and alot of instabilities occured even after i adjusted my revit model over and over with repairing the robot File
here's a link to The Revit File
http://www.4shared.com/zip/Pcs_Ui5u/latest_edition.html?
Sorry to say that but your model is so inaccurate.
But I manage to correct it my way in Robot:
- no kinematic links,
- no regular mesh,
- model generation tolerance set 1mm
- arc balcony redefined to fit @beams@ discretization
- columns should be defined from slab to slab
- supports should be defined at the column bottom nodes , not at additional nodes aside columns
Model: http://www.4shared.com/zip/jkL1X0Lv/Tmlk89_2013.html
