I was wondering if someone could help me out. Despite my best efforts, I cannot get the Analytical Model from my revit file to come in correctly into Robot.
When I try to transfer the model over, some elements are missing, columns are shifted over, beams are shifted over, connections are lost, and everything seems to be jumbled. This is shown easily by looking at the top views of the Revit Analytical Model and the Robot Model. The roof joists are all over the place in the robot model, when they should be 2' spacing O.C.
I also attached the copy of the events report from sending the model from Revit to Robot. As you can see, there are a few "Degenerated Model" warnings. I was wondering if that has something to do with the problem
If anyone could tell me why this happenning or how to correctly transfer the model over, I would greatly appreciate it.
Thanks, in advance
Solved by Rafal.Gaweda. Go to Solution.
Sorry, I know it's a dumb question.. What email should I send it to? The file is 3MB after purging, deleting the file history and zipping it; so I can't attach it to the post.
Please try to use e.g.:
http://www.yousendit.com/download/WUJiaUNDeFU3bUROTzhUQw
Ok, let me know if this works.
Thanks for your patience
Thanks for the answer it looks like I just need to sure up some of the innaccuracies.
I didn't see those innaccuracies.
Thanks also for the very timely responses.
I am attaching corrected robot model for your consideration while correcting RST model.
Thank you so much! This is a tremendous help! You guys at autodesk are the best!!
My sincerest gratitudess!
