Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Revit -> Robot model corection problem
15 REPLIES 15
Message 1 of 16
bartosz_borowiak
712 Views, 15 Replies
I am working with Robot model gathered from Revit. Unrotunately I don't have acces to Revit model to correct it before sending to Robot. I cleared most of inaccuracies but still it takes ages to generate computinal model and than analyise it. I will be very grateful for any guideline how to deal with it and make model lighter.
Bartosz Borowiak
Link to model file: http://www.filemail.com/d/ganmmgvhbpkklju
15 REPLIES 15
Message 2 of 16
Did you?
What about unmeshed panels? What abot concertation of meshes -> something wrong with geometry.
Search forum for topics about model correction, inaccuracies, meshing
HInts: do not use regular mesh, do not use kinematic links, for this model I recommend min 1m mesh, try to mesh walls first then the rest.
Rafal Gaweda
Message 3 of 16
Rafal.Gaweda
in reply to: Rafal.Gaweda
To start - use this model: http://we.tl/tJJFt78jlb
Some walls geometry is corrected but....
The rest must be done by you - either correct only meshes or geometry and meshes
Rafal Gaweda
Message 4 of 16
Witaj Rafal, Thank you for that model but,
In the meantime I did corrected geometry and applied preferences about generating mesh. Still having problem to analysis it with selfweight. It's my first time working with revit exprted model and I'm getting my nerves with it.
Attached  model:
http://www.filemail.com/d/ofawbuyxbebbxqo
Kind regards
Bartek
Message 5 of 16
Why didn't you correct my ~30000 nodes model?
If you want to use yours - 371000 nodes - your choice but you need to have 12+ GB RAM memory and time.
Rafal Gaweda
Message 6 of 16
In th emeantime I was correcting my geometry and I thought that will be better model. I will corect yours with less node and we will se what will happen. Thank you
Message 7 of 16
30-40 thousand node model is OK for this structure.
Go in this direction.
Rafal Gaweda
Message 8 of 16
Thank you for that hint. In fact it was so much easier and quicker working on that "light" version of model with less nodes. My corrected model attached below, still with some meshing problems. Thank in advance for help.
http://www.4shared.com/zip/ms_QGSOece/JLP_BB.html
Message 9 of 16
I'm aware that those are locations of the meshing problem but can't really figure out how it can be even better corrected.
Message 10 of 16
File please
Rafal Gaweda
Message 11 of 16
http://www.filemail.com/d/rafqbbmqyvmkhnn
Thank you in advance.
Bartosz
Message 12 of 16
Rafal.Gaweda
Examples how to correct meshes on frozen panels
http://screencast.com/t/dIrFiEqgel
http://screencast.com/t/VPw5h8sgejm
Rafal Gaweda
Message 13 of 16
Anytime I correct one section of incoherent mesh during verification Robot finding another one. Looks like never-ending job.
Message 14 of 16
Inaccurate Revit model...
After some corrections please run Correct function to merge ovelaping nodes.
Rafal Gaweda
Message 15 of 16
I did manage model to work.  There is one issue which concerns me. When I was " correcting" the mesh nodes in order to have a diagonal members to take some compression load I lost the intersection between some of them (screen attached). I would like to push all the nodes into one plane (ideally the edge of the floor panels) so in lateral stability analysis it will work how it should be. Any quick method to do so?  File: http://www.filemail.com/d/bhzklbdprgiholw
Message 16 of 16
Detailed Correct -> To Plane ?
Rafal Gaweda
