Discussion Groups
Robot Structural Analysis
Product Support
Rafal.Gaweda
Re: [Revit-Robot] How to clean in Revit all Robot data
06-04-2012 02:26 AM in reply to: Rafal.Gaweda
Ready for RST 2013.
It clears all Revit Extensions parameters together with RST-Robot link parameters.
Copy attached files with folder from zip to
[c:\ProgramData\Autodesk\Revit\Addins\2013]
So it should be :
c:\ProgramData\Autodesk\Revit\Addins\2013\DREXProjectCleaner\DREXProjectCleaner.dll
c:\ProgramData\Autodesk\Revit\Addins\2013\\DREXProjectCleaner.addin
Then this module will be available in Add-Ins tab as shown below:
To run it just press OK on next window
Rafal Gaweda
Please use plain text.
Product Support
Rafal.Gaweda
06-04-2012 09:05 AM in reply to: Rafal.Gaweda
For 2012
[c:\ProgramData\Autodesk\Revit\Addins\2012]
So it should be :
c:\ProgramData\Autodesk\Revit\Addins\2012\DREXProjectCleaner\DREXProjectCleaner.dll
c:\ProgramData\Autodesk\Revit\Addins\2012\\DREXProjectCleaner.addin
Rafal Gaweda
Distinguished Contributor
CristianLANCULESCU1367
06-05-2012 03:20 AM in reply to: CristianLANCULESCU1367
CristianLANCULESCU1367 wrote:
I've erased RM_R2R_LinkSessionIdList, RM_R2R_OriginOffset and RM_RSLoads. Now When I export to Robot I get an Error/Warning saying: "Parameter RM_R2R_OrginOffset, RM_R2R_LinkSessionIdList, RM_RSLoads not defined in shared parameters file "C:\Program Files\...\RMParam.txt".
It doesn't cause any problems, but I'm still curious why this appears.
Can I do something about that?
Product Support
Rafal.Gaweda
06-05-2012 03:28 AM in reply to: CristianLANCULESCU1367
I've erased ....
Have you done it manually or by this addin?
Rafal Gaweda
PatrickEC
06-06-2012 02:03 PM in reply to: Rafal.Gaweda
Could you consider publishing the source code for this script? I am sure the advanced users would appreciate it.
Product Support
Rafal.Gaweda
06-06-2012 03:35 PM in reply to: PatrickEC
No, sorry.
These Addins are developed by ADSK, copyrighted etc.
Rafal Gaweda
06-07-2012 04:45 AM in reply to: Rafal.Gaweda
RG_Adsk wrote:
I've erased ....
By hand
Product Support
Rafal.Gaweda
06-07-2012 05:20 AM in reply to: CristianLANCULESCU1367
Use clear then chek.
Rafal Gaweda
PatrickEC
05-23-2013 12:51 PM in reply to: Rafal.Gaweda
I will appreciate a new 2014 version of this plugin.
PatrickEC
05-23-2013 03:19 PM in reply to: PatrickEC
I am trying to run this on 2013 now and I think it is installed correctly, because it shows up in the External Tools menu. But when I click to run it, it does not seem to be doing anything, there is no message no nothing. And Robot data are still there.
