I used to use ROBOBAT in 2005, and I remember there was a retaining wall design module(similar to footing design in RSA), this module used to check sliding and overturning as well it used to structurally design the wall sections and provide reinforcement.
Is that an addin or it has been removed?!
I hope it is still there
Search for Robot Expert.
I don´t know if it is still available.
Sometime ago it was available through subscription to french speaking users.
You were able to use a trick and change your region to France.
Rafael Medeiros
Dear Sir,
This French article is very useful to download The Expert for the later version of robot 2012.
Thanks to the French Forum Robot team.
Wassim
Thank you for your help Wassim!!
I hope RSA team to add the retaining wall design to the foundation module as it is very helpfull. not sure why they added it only in the french version 😞
