Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Retaining wall
4 REPLIES 4
mgaafar
882 Views, 4 Replies
Retaining wall
          I used to use ROBOBAT in 2005, and I remember there was a retaining wall design module(similar to footing design in RSA), this module used to check sliding and overturning as well it used to structurally design the wall sections and provide reinforcement.
Is that an addin or it has been removed?!
I hope it is still there
4 REPLIES 4
Rafacascudo
in reply to: mgaafar
Search for Robot Expert.
I don´t know if it is still available.
Sometime ago it was available through subscription to french speaking users.
You were able to use a trick and change your region to France.
Rafael Medeiros
Since 2011 this tool has been removed, if you have it reinstall this version together with expert tool.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
in reply to: StefanoPasquini6790
Dear Sir,
This French article is very useful to download The Expert for the later version of robot 2012.
http://forums.autodesk.com/t5/Robot-Structural-Analysis/ARTICLE-installation-modifi%C3%A9e-des-outil...
Thanks to the French Forum Robot team.
Wassim
mgaafar
Thank you for your help Wassim!!
I hope RSA team to add the retaining wall design to the foundation module as it is very helpfull. not sure why they added it only in the french version 😞
