Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Results for beams in many points
7 REPLIES 7
Message 1 of 8
sirkris
431 Views, 7 Replies
I have slab supported on RC beams, and I can see results for many points. I do  to set up number of points (or I do not remember I did it).
Where can I change the number of points where results are shown?
Such points  are shown only for beams and columns have results shown only for ends.
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
in reply to: sirkris
Below:
Rafal Gaweda
Message 3 of 8
sirkris
in reply to: Rafal.Gaweda
On picture above I have example where for "ALL" I still can see only local extremes. My question is, where can I change the number of points on beam for "ALL".  For my picture I probably have somewhere set up this number to 0, In previous picture it was set up for example to 10. Question is where are such settings.
Message 4 of 8
Rafal.Gaweda
Not possible.
Rafal Gaweda
Message 5 of 8
sirkris
Is there any rule which explains  where Robot does assume such points?  I have beams where there are different numbers of such points. 18.PNG
Message 6 of 8
Rafal.Gaweda
Zoom only : http://screencast.com/t/K1HUGZed
Rafal Gaweda
Message 7 of 8
sirkris
This is not the issue with Robot bug about labels visibility.    I mean there is no rule about  black squared points positions.
It does not matter how far I zoom - labels can be visible only for black points on beams. In your example black points are quite dense . When you lokk at picture I sent, you notice that  spacing of points id different for different beams.  b>a
By the way - is Autodesk going to do sth with labels visibility ? This bug makes printouts composition quite useless.
Message 8 of 8
Rafal.Gaweda
