I got some extreme values in my provided reinforcement map and want to take a look at the required reinforcement map to see if I can ignore these values. But the map has only black color and it is impossible to read the values. Is it a way that I can make Robot showing me the more colors? See also the picture.
Solved by Artur.Kosakowski. Go to Solution.
What happens if you delete the slab from the RC mode of the Inspector and import it again from the model?
Could you attach the model and list the steps to follow please? Thank you.
I followed the steps you described but in my case all looks fine. I will send you the details how to download 'my' file in a separate message. Please check if you can see the map correctly.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
