Hi
Please find the attached file. I'm facing a problem with req'd reinforcement. the program will not respond. I tried it with other files (rtd) but the same problem exist.
Could you attach the rtd file and describe step by step the actions to follow please?
I can't see any issue. What were your steps?
Hi
It's not my first trial.
I choose Design>> Required reinforcement of RC beams/columns. The program will not respond. It's happening for all my files. Earlier it was working properly. I don't know what happenend.
Try to delete the temporary files from your computer (%temp% folder) as well as rename your CfgUsr folder (C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2014\CfgUsr)
Hi Please find the attached files.
Step by step
1- Require reinforcement calculation: Responding
2- RC member calculations report: responding
3- Rc member calculations table: not responding
Can you see the table when you switch to the Required reinforcement layout?
