Mirko.Jurcevic
351 Views, 1 Reply
Remove slab corners
Hi!
I have very simple task and I am unable to do it.
I modeled rectangular slab and I want to delete its corners. I tried drawing two polyline contours and tried to add opening to them but i doesn't seem to work. Then I tried to draw random opening in the middle of slab and then Robot creates openning at the corners also.
I know that I could draw whole slab contour from the beginning but I don't want to do that. I want to be able to make changes to existing slab.
I am attaching my file, if it's not a problem, video would be nice  🙂
Corner polylines are in file.
Thanks!
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
1 REPLY 1
Please check: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Trim-slab-corner/m-p/3876432
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
