Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Reinforcement ratio
7 REPLIES 7
Message 1 of 8
HoshangMustafa
479 Views, 7 Replies
Reinforcement ratio
Hi
Please find the attached file. How can I change reinforcement ratio? I receiver an error message in column design module indicating that reinforcement is less than 1%.
7 REPLIES 7
Message 2 of 8
You can e.g. try to set smaller spacing among reinforcement bars.
Artur Kosakowski
Message 3 of 8
Hi Artur
Why the reinforcement ratio is in a dialogue box in the case we can't modify it (put another value)? instead the programmer can put a reinforcement ratio implicitly in a setting. The same thing with reinforcement weight (kg/m3)
Message 4 of 8
I think you confuse the optimization with restrictions imposed on reinforcement distribution. that prevents generation of larger amount of reinforcement.
Artur Kosakowski
Message 5 of 8
Hi
I wrote in the first post:
Your last post was:
Your last attachment is for a beam arrangement
Message 6 of 8
You missed the file. For the reinforcement pattern there situation I described is valid for both beams and columns.
Artur Kosakowski
Message 7 of 8
Hi
Please find the attached file. How can I get rid of this error?
Message 8 of 8
Could you send me the rtd file with this column please?
Artur Kosakowski
