Reinforcement pattern option the laptop are hang
4 REPLIES 4
hardware
412 Views, 4 Replies
I am facing problem Autodesk Robot Structural Analysis Professional 2014
which is one of the software at Autodesk Infrastructure Design Suite
Ultimate 2014.Which installed in laptop.
The problems were :
1.To Design RCC(Reinforcement Cement Concrete)structure when i click the
Reinforcement pattern option the laptop are hang.
pic 2.jpg-image/jpeg(262 k)
When it is hang there is no other option to restart the computer.
2.when i select the beam & open the beam option it open the foundation
option.
Foundation.jpg        -image/jpeg(205 k)
3.Some other problem I also face.I cannot understand those problem but i
give those snap.
pic 3.jpg-image/jpeg(265 k)
4 REPLIES 4
asburyj
in reply to: hardware
I am moving thread to the Robot Board as they have a better understanding of feature related issues.
Jeffry Asbury
Romanich
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Artur.Kosakowski
Try to reduce the hardware acceleration (http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Robot-2014-plate-not-displaying/m-p/3894242) and delete the temporary windows file.
You may also try to rename the CfgUsr folder (e.g. to 1_CfgUsr) located in C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2014 folder.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Hi there,
I am having the same problem with my robot structural analysis. Everything runs fine until i attempt to do reinfircement design. More example, if i click on "Reinforcement patterns", it brings up a windows installer prompt as if the proram is attempting to installing something but the installer just hooks for a long time.
I have attempted both possible solutions in this post but i was hoping there could be anothe solution? Kindly help.
