When I calculate long beams ROBOT divides the reinforcement in smaler segments than requested.
How can I change the parameters so ROBOT doesn't divide the reinforcement more than necessery.
Solved by Rafal.Gaweda. Go to Solution.
thank u so much. 1-but if send (AS) for Revit Structure .the detailing in revit contained it ? (fig1)
2-how I control AS minimum for a)bending b) for torsion ? fig(2)
3- what is benifit of typical rienforcement? fig(3)
Re.1 This is Required Reinf module. Activate Mx here:
Re.2
Re.3
You can force program to generate and verify reinforcement give by You using this option.
thank v.much durng calculation of rienforcement this error apear. how can solve it?
