Discussion Groups
Robot Structural Analysis
leoemmett12345
Reinforcement calculation issues
595 Views, 15 Replies
03-25-2013 06:10 AM
I am modelling a cylindrical liquid retaining reinforced concrete strucutre.
I currently have two issues, (I am sure I will find many more!!)
firstly my base slab (13 in this case) gives the error message "incorrect reinforcement direction" I want it to be a two way spanning slab how do I change this?
Secondly, when trying to calculate the required reinforcement for pannel 1. I get the error message "indicated objects must be in the same plane" I have tried using edit -> detailed correct and then change it to the correct pannel orientation (see attached), however I still get the same error message. It is most frustrating! does anyone know why, because as far as I can see I have changed the plane.....
also will robot have issues for calculating the reinforcement for my cylindrical exterior walls?
I have attached my robot file and also a screen shot to show how I have been trying to change the plane.
Thanks for any help/advice you can give.
Please use plain text.
Product Support
Artur.Kosakowski
Re: Reinforcement calculation issues
03-25-2013 06:22 AM in reply to: leoemmett12345
It seems that you defined the direction of the main reinforcement as perpendicular to the panel.
For other points - you missed the attachments.
Artur Kosakowski
leoemmett12345
03-25-2013 06:37 AM in reply to: Artur.Kosakowski
It wont let me add the file as it is too large, can I email it to you?
Product Support
Artur.Kosakowski
03-25-2013 06:47 AM in reply to: leoemmett12345
leoemmett12345
03-25-2013 06:50 AM in reply to: Artur.Kosakowski
Product Support
Artur.Kosakowski
03-25-2013 07:42 AM in reply to: leoemmett12345
For panel 13 as I assumed you have to redefine the direction of reinforcement (see the attached picture)
For the export of the panel 1 to the RC Provided Slab reinforcement module: you have to redefine the panel as extruded ones are currently not supported. You need to define it as e.g. a vertical contour with 4 points.
Artur Kosakowski
leoemmett12345
03-25-2013 08:02 AM in reply to: Artur.Kosakowski
Thanks, ill let you know how it goes,
leoemmett12345
03-25-2013 01:06 PM in reply to: leoemmett12345
I have changed the panels to contours. Now I am having real issues with trying to apply the mesh. I started going with the coons with rectangular elements and that hasn't worked, since I have tried all manner of meshes all with no luck. Can you offer any advice?
please see this:
http://www.4shared.com/file/aYarvaIr/ver3_anothermesh.html
thanks for your help.
Product Support
Artur.Kosakowski
03-26-2013 01:20 AM in reply to: leoemmett12345
Try to follow the steps shown on the attached pictures (starting with your original model).
Artur Kosakowski
leoemmett12345
03-26-2013 04:50 AM in reply to: Artur.Kosakowski
Hi thanks again, I have changed them but now I cant apply a thickness to some of my panels, Whenever I go to the panel properties and change it to TH500 it selects it then doesn't actually go through with the selection! I am sure it is some small thing that I am missing! Any suggestions?
http://www.4shared.com/file/VEAbiWCo/ver8pumps_3D.html?
