Discussion Groups
Robot Structural Analysis
Valued Contributor
Jesper.Jensen
Accepted Solution
Reinforcement Designer - Manually modifying input parameters
363 Views, 9 Replies
08-12-2012 11:30 PM
When using the reinforcement designer and calculating required reinforcement for SLS to CP65 this is done limiting the crack width to 0.3mm. If on a specific job I need to do the same calculations, but limit the crack width to 0.25mm, is there a way to do so in Robot?
Thanks in advance,
Jesper
Please use plain text.
Product Support
Artur.Kosakowski
Re: Reinforcement Designer - Manually modifying input parameters
08-13-2012 12:30 AM in reply to: Jesper.Jensen
1. Increase unit precision in Job Preferences
2. Set crack limit
Artur Kosakowski
Valued Contributor
Jesper.Jensen
08-13-2012 11:25 PM in reply to: Artur.Kosakowski
Thanks Artur that's great, but how do you bring forward the CP65 Reinforcement Parameter Tab?
Jesper
Product Support
Artur.Kosakowski
08-14-2012 12:18 AM in reply to: Jesper.Jensen
I'm afraid that I don't understand the question. Could you rephrase it please? Thank you.
Artur Kosakowski
Valued Contributor
Jesper.Jensen
08-15-2012 07:03 PM in reply to: Artur.Kosakowski
If you open the attachement you made in your first reply, the bottom picture show a tab called "CP65 Reinforcement Parameters" where the crack width can be modified. Can you please let me know how I can access or open that window in Robot?
Jesper
*Expert Elite* | International Moderator
Romanich
08-15-2012 09:27 PM in reply to: Jesper.Jensen
Hi Jesper,
Valued Contributor
Jesper.Jensen
09-06-2012 12:30 AM in reply to: Romanich
Thanks for the previous replies, answers were perfect. I've another question in relation to the crack width calculations I'm hoping you can answer. I assume the crack width is calculated in the location as indicated on the attachment (between the bars at a distance acr) is that correct?
If I specify a 200mm cover, is there a way I can force Robot to calculate the crack width at a distance 40mm from the outermost bar, and not at the face?
Jesper
Product Support
Artur.Kosakowski
09-06-2012 01:54 AM in reply to: Jesper.Jensen
I'm afraid that I don't understand the question. Robot calculates cracks in these locations (s is based on calculated require reinforcement area and declared bar diameter).
Artur Kosakowski
Valued Contributor
Jesper.Jensen
09-06-2012 05:23 PM in reply to: Artur.Kosakowski
Yes, that was my assumption as well.
In the dialog box shown above (4 in red brackets) called "CP65 Reinforcement Parameters" I can define the top/bottom cover under the tab called "Reinforcement".
If I set the cover to 200mm, is there a way to force Robot to calculate the crack width 40mm away from the reinforcement, instead of at the concrete face 200mm away?
Jesper
Product Support
Artur.Kosakowski
09-06-2012 11:46 PM in reply to: Jesper.Jensen
I'm sorry but there is no such possibility.
Artur Kosakowski
