Reinf.Calc problem
21 REPLIES 21
Message 1 of 22
MUHANNAD.ABU_ABDO
624 Views, 21 Replies
Reinf.Calc problem
What's the solution for this problem plz ??
Muhannad M.Abu Abdo
Structural Design Engineer
Tags (1)
21 REPLIES 21
Message 2 of 22
Hi, check the material of your beams, probably is the default one...chose a specific material in the reinforcement settings.
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 22
i'm sure of material kind .. and i'm talking about error in the reinf.calc ??
Muhannad M.Abu Abdo
Message 4 of 22
File please.
Rafal Gaweda
Message 5 of 22
this's the file ..
http://www.filemail.com/d/jrydkzixcvcbwtg
Muhannad M.Abu Abdo
Message 6 of 22
I do not see any problem:
Rafal Gaweda
Message 7 of 22
I don't know really .. anyway i want to ask could i design the connection between column and beam ? nd how i could get the drawings ?
Muhannad M.Abu Abdo
Message 8 of 22
Connections?
These are concrete members, no such design in Robot.
Rafal Gaweda
Message 9 of 22
but there's option for connection design in RC Elements??
Muhannad M.Abu Abdo
Message 10 of 22
First look at the option, then ask.
Rafal Gaweda
Message 11 of 22
Yes you're right ..
Muhannad M.Abu Abdo
Message 12 of 22
Can i ask another question ?
Muhannad M.Abu Abdo
Message 13 of 22
Sure
Rafal Gaweda
Message 14 of 22
I want to learn how i can apply wind load cases on the structure ? and get the results
thanks in advance
Muhannad M.Abu Abdo
Message 15 of 22
Create simple load case(s) with Wind nature, add loads.
Rafal Gaweda
Message 16 of 22
I ask you cuz i don't know how ! even i don't know if robot can give me the failure modes !?
thanks in advance rafal
Muhannad M.Abu Abdo
Message 17 of 22
Rafal Gaweda
Message 18 of 22
Can you show me by short video how i applied wind load on structure .. if you want if you don't nevermind
thanks in advance
Muhannad M.Abu Abdo
Message 19 of 22
Apply loads in the same way as you do for other load case.
Calculate load value(s) (according to code) by your own, apply them to, for example columns, edge beams or outer slabs edges or add claddings or curtain walls as outer walls and load them
Rafal Gaweda
Message 20 of 22
Okay i will apply loads as point load on the nodes (connect column to beam ) .. my question is i will apply this load on the outer frame and internal frame also or just for outer frames !!
Muhannad M.Abu Abdo
