Good Morning / evening ;
Retrieving Values of Reduced Forces (NRx) on the bottom of a wall comes to make a integral value on its Nxx along the length cut . so all its bottom nodes are took into account.
But when having a series of walls connected between themselfs , there is a common nodes between theme at there bottom.
so the sum of reduced values obtained by the table "Reduced Results on a panel" should be (normally i guess) bigger that the reduced force obtained by doing a cut on these walls at once ( Menu - Panel cuts ).
explanation please ...
My need is to compute the reduced results on a serie off panels and columns by API , so i guess i have two methods to do it ( if there is anothers , they are welcome ) :
F1. Sum of Nrx and Mrz for each wall and column and reporting them to a given point.
F2. Gettin Nxx at the bottom of each node at the bottom of all walls and Fx of columns and reporting them to a given point
My fear is that the F1 >> F2 in some cases.
Thank you.
Solved by Rafal.Gaweda. Go to Solution.
Reduced results accuracy depends on FE size:
Maybe you are looking for stories results:
Good Morning / Evening ;
Ok , the difference seems to acceptable ...
for the second point , the goal is a little bit different [ just a set of walls and all of those at a given storie ].
Thank you
I guess that in order to define a core walls as a unique entity , they should be connected at there edges.
Alm i right ?
in my case i trying to get reduced forces by using a "frontal method" : getting reactions ( N, M ) at every node on the base of walls ( of any distribution ) and then reduce efforts to a given point ( case when i want to get reduced forces from a distribution of walls and columns to apply a to a Raft ).
Thank you
Alm i right ?
No.
Try.
