Discussion Groups
Robot Structural Analysis
m_zaman
Accepted Solution
Reactions direction in seismic result
385 Views, 1 Replies
09-10-2011 04:25 AM
Hi
I have some problems with reaction direction in seismic analysis.
In reaction table I can't see the uplift force( minus force).
Could you please help me to understand how can I consider uplift?
Please use plain text.
Product Support
pp2008
Re: Reactions direction in seismic result
09-11-2011 11:20 PM in reply to: m_zaman
in case of seismic analysis using response spectra method results are given for qudratic combinations. When calculating quadratic combinations (square root of the sum of squares or more advanced types like CQC) the information about sign is lost. It is what is seen on your screen capture.
In Robot this information can be restored specifying main mode - see the attached screen capture. In such case quadratic combinations of results are multiplied by the sign of appropriate result for selected vibration mode (the main or dominating one).
In case of default settings of job preferences (results for quadratic combinations saved inside a project) it is necessary to re-run analysis after setting the main mode.
If this post answers your question please click "Accept as Solution".
It will help everyone to find answer more quickly!
Best regards,
Pawel Pulak
