Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
xinlok
393 Views, 3 Replies
Reaction Forces
Is the reaction which I got after calculation (Result, Reaction) is the one which I can use to calculate the design of the footing.
for example, in the attached photo, the reaction at node 1 is for exampleFz = 64355.24 kg.
I can use this force to calculate the design of footing?
Regards
3 REPLIES 3
tony.ridley
in reply to: xinlok
It's not really a Robot question though, is it.........
  • which code are you designing to?
  • ultimate or allowable soil capacity?
  • what kind of footing?
  • no idea which load combination or factors you are using..
  • etc
  • etc
too many variables here to help you.  maybe better to ask your tutor at uni?
xinlok
in reply to: tony.ridley
Thanks tony for answering my question,
I just want to be sure if this reaction which i got from the robot is the one which i can use to design the footing with regardless to all the above variable mentioned above.
I am not sure if my question is clear,
Thanks and regards
tony.ridley
in reply to: xinlok
If you mean "do you use the reactions table to find forces so you can do footing design" then the answer is yes.
Load cases / combination that you should use are up to the local code.
