I am trying to use moving loads in a model. I have been able to create and correctly place and apply the loads. Everything seems to work allright at the moment.
But the problem is that every time I start the solver, it creates moving load cases with random numbers. For example, if I create a moving load case with the number 60. I find myself with other load cases at numbers 4, 5, 23, 24, 25 (which were free before).
This is not really a computation problem but it's messy and very annoying ! Is there a solution out there ?
Thanks.
Regards.
I assume you refer to top and bottom envelope filters generated automatically by Robot. You may try to keep the continuous numbering of simple load cases and define the moving loads at the end of the list.
Yes, actually I just noticed they were envelope cases associated with the moving load case.
So there's no way to specify a custom number for theses cases ?
Regards.
