Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Raft with Ground Beams
1 REPLY 1
stroxy
366 Views, 1 Reply
Hi
  1. What is the difference between elastic ground bars from the geometry>additional attributes menu and elastic linear support from the geometry supports menu?
  2. If I have a raft with integrated beams, do I assign elastic supports to the raft and then additionaly assign elastic ground bar properties (or elastic linear support) to the beams?
1 REPLY 1
Artur.Kosakowski
in reply to: stroxy
1. The later can be applied to the edges of the panels only.
2. No, this will 'double' the elasticity along the beams.
Artur Kosakowski
