RSAPro 2012 ANSI/AISC 360-05 Cb Parameter
2 REPLIES 2
memoalcr
570 Views, 2 Replies
In RSAPro 2012 steel design for ANSI/AISC 360-05; when trying to define the Cb parameter for "Lateral Buckling", the window for selecting the Parameter Cb does not pop-up (see attached file). Is this a software problem or am I missing a design step?
2 REPLIES 2
Artur.Kosakowski
in reply to: memoalcr
Thank you for indicating this issue. We will investigate it.
Artur Kosakowski
Artur.Kosakowski
Please download and install SP3 for Robot 2012. Mind to select the correct version of the SP (Professional or Standard version as well as 32 or 64-bit OS).
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=13140816
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
