Discussion Groups
Robot Structural Analysis
Active Contributor
SamKa85
RSA Crashes when opening dxf file
199 Views, 6 Replies
09-19-2013 07:16 AM
I am trying to open a dxf file in shell model but iRSA keeps crashing after I click OK in "Parameters of loading DXF/IGES- format files" dialogue box.
I have RSA Professional 2013 and it is up to date as the attached image shows
Also, dxf file is attached
Please use plain text.
Product Support
Artur.Kosakowski
Re: RSA Crashes when opening dxf file
09-19-2013 07:54 AM in reply to: SamKa85
I can't see any problem with doing that. I'm attaching the rtd file.
Artur Kosakowski
Active Contributor
SamKa85
09-19-2013 09:04 AM in reply to: Artur.Kosakowski
For some reason , it is not working on my PC. I guess I won't be able to use this feature :smileyhappy:
Product Support
Artur.Kosakowski
09-20-2013 12:32 AM in reply to: SamKa85
Try to unmark the indicated check box
Does it make any difference?
If not, send the crash report and let me know what email address you entered in the form so that I can find it please. Thank you.
Artur Kosakowski
Active Contributor
SamKa85
09-20-2013 03:47 AM in reply to: Artur.Kosakowski
I have already tried that but it did not work
As for the report, my e-mail address is msmars@gmail.com
Thank you ,
Product Support
Artur.Kosakowski
09-24-2013 01:40 AM in reply to: SamKa85
Are you able to open this dxf file in AutoCAD (if installed) on the same computer?
Artur Kosakowski
Active Contributor
SamKa85
09-24-2013 11:38 AM in reply to: Artur.Kosakowski
Yes, I can.
