A screen capture from detailed analysis goes crazy when trying to output it through a word file.
Also ,if you save the file with another name and then , after new modifications ,you try to close it through the "X" , it asks you if you want to keep the changes from the 1st file you opened.It saves over the latest filename , but it is confusing
Both are on Jing movie in http://screencast.com/t/fhqxAB3Ogl
Rafael Medeiros
Robot Structural Analysis
Solved by Artur.Kosakowski. Go to Solution.
Thank you for sending these remarks. We will investigate both issues.
Both issues have been corrected in SP2 for Robot 2014.
Rafael Medeiros
It should be available later today or at the beginning of the next week. Mind that it will be available first from the Communication Center in Robot and then from the update site.
