Here below several issues with tables.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
- Table template doesn't work correctly - after modification of columns, order of columns are switched to default. Please see this video: http://screencast.com/t/LuBGRAFhn
Got it
- Is it possible to realize the ability to save\load different table templates for one table (as for Job preferences etc.)?
No
- Can you upload the list with table template codes for files with name txxx.tbl - which number for which table?
First on the list below = 0, then +1 each
enum RL_MENU_OPTIONS
//the order of viewer's numbers in similar subject groups is VERY important !
RL_VIEW_NODES , //nodes group
RL_VIEW_DISPLNOE ,
RL_VIEW_REACTIONS ,
RL_VIEW_TRANSCIENT ,
RL_VIEW_ELEMENTS , //elements group
RL_VIEW_EFFORTS ,
RL_VIEW_STRESSES ,
RL_VIEW_DISPLELE ,
RL_VIEW_MATERIAL ,
RL_VIEW_MEASURE ,
RL_VIEW_PSEUDO ,
RL_VIEW_PROPERTIES ,
RL_VIEW_DYNAMIC , //mode group
RL_VIEW_BUCKLING ,
RL_VIEW_SUPPORTS , //independent
RL_VIEW_LOADS , //independent
RL_VIEW_LOADS_EDIT ,
RL_VIEW_MASSES , //independent
RL_VIEW_MASSES_EDIT ,
RL_VIEW_COMBINATIONS ,
RL_VIEW_GROUPS ,
RL_VIEW_PONDERATION ,
RL_VIEW_REINFORCEMENT ,
RL_VIEW_ELEMENTSFINITE,
RL_VIEW_PANELS,
RL_VIEW_EF_DATA,
RL_VIEW_GLOBAL_MB,
RL_VIEW_GLOBAL_EF,
RL_VIEW_DETAIL,
RL_VIEW_PROPERTIES_PANELS,
RL_VIEW_MEASURE_PANELS,
RL_VIEW_RDIM,
RL_VIEW_PROPERTIES_CABLES,
RL_VIEW_PROPERTIES_JARRETS,
RL_VIEW_OFFSETS,
RL_VIEW_SUPPORTS_LABEL, //independent
RL_VIEW_LIARIG_LABEL, //independent
RL_VIEW_MOBIL_LINE, // TJ mobil
RL_VIEW_BEST,
RL_VIEW_ESTIM,
RL_VIEW_CUTS,
RL_VIEW_TEMP_LINE,
RL_VIEW_PANEL_RR,
RL_VIEW_PROPERTIES_VOLUME,
RL_VIEW_SOLIDS,
RL_VIEW_SOLIDS_FE,
RL_VIEW_SOLIDRESULTS,
RL_VIEW_PUSHOVER_LINE,
RL_VIEW_CURVE_LINE,
RL_VIEW_ADVANCED_LINE,
RL_VIEW_IMPERFECTIONS,
RL_VIEW_VOLCUT,
RL_VIEW_ELAPLA,
RL_VIEW_PROPERTIES_MATERIAL,
RL_VIEW_GROUPS_VAL,
RL_VIEW_GROUPS_NODE,
RL_VIEW_GROUPS_OBJ,
RL_VIEW_GROUPS_ES,
RL_VIEW_GROUPS_LOA,
RL_VIEW_LOADS_EDIT_TEXT,
RL_VIEW_STOREY,
RL_VIEW_MEASURE_SURF,
RL_VIEW_MEASURE_VOL,
RL_VIEW_MASSES_CONV,
RL_VIEW_EF_PANEL,
RL_VIEW_STOREY_FRED,
RL_VIEW_FINT,
RL_VIEW_FOC,
RL_VIEW_FOC_LINE,
RL_VIEW_FF,
RL_VIEW_FF_LINE,
RL_VIEW_LOADS_NOTIONAL,
RL_VIEW_CORWALLS,
RL_VIEW_STOREY_DEPL,
RL_VIEW_END
In the Robot 2015 issues from the first topic still exist. I tried to solve p.2 by the API but have found some bugs (or maybe it was features 😉
Method AddColumn() accept integer data type. But I have not found any info about it (do you have this list with column internal numbers?) Maybe it will be useful if enumerator will be implemented instead of numbers.
Also this situation should be fixed:
.AddColumn(-100); //any negative number
return:
Moreover, I think the internal check in Robot should be implemented - if column exist on the current table, user can't add the same one:
for (int i = 0; i < 5; i++) { tableReaction.AddColumn(25); }
It will be a great, if in the next version will be implemented methods like DelColumn()(to delete unnecessary columns), MoveColumn() (to simulate drag drop by user).
Roman Zhelezniak
In the Robot 2016 issues from the first topic still exist.
Roman Zhelezniak
