Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Romanich
476 Views, 4 Replies
RSA 2014: Tables
Here below several issues with tables.
  1. Table template doesn't work correctly - after modification of columns, order of columns are switched to default. Please see this video: http://screencast.com/t/LuBGRAFhn
  2. Is it possible to realize the ability to save\load different table templates for one table (as for Job preferences etc.)?
  3. Can you upload the list with table template codes for files with name txxx.tbl - which number for which table?
  4. Maybe it will be better to provide button Import\Export from Excel (like in SAP2000) in addition to copy\paste.
  5. Incorrect menu name:Tables_2.png
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Tags (1)
4 REPLIES 4
Rafal.Gaweda
in reply to: Romanich
Got it
  1. Is it possible to realize the ability to save\load different table templates for one table (as for Job preferences etc.)?
No
  1. Can you upload the list with table template codes for files with name txxx.tbl - which number for which table?
First on the list below = 0, then +1 each
enum RL_MENU_OPTIONS
  //the order of viewer's numbers in similar subject groups is VERY important !
  RL_VIEW_NODES         , //nodes group
  RL_VIEW_DISPLNOE      ,
  RL_VIEW_REACTIONS     ,
  RL_VIEW_TRANSCIENT    ,
  RL_VIEW_ELEMENTS      , //elements group
  RL_VIEW_EFFORTS       ,
  RL_VIEW_STRESSES      ,
  RL_VIEW_DISPLELE      ,
  RL_VIEW_MATERIAL      ,
  RL_VIEW_MEASURE       ,
  RL_VIEW_PSEUDO        ,
  RL_VIEW_PROPERTIES    ,
  RL_VIEW_DYNAMIC       , //mode group
  RL_VIEW_BUCKLING      ,
  RL_VIEW_SUPPORTS      , //independent
  RL_VIEW_LOADS         , //independent
  RL_VIEW_LOADS_EDIT    ,
  RL_VIEW_MASSES        , //independent
  RL_VIEW_MASSES_EDIT   ,
  RL_VIEW_COMBINATIONS  ,
  RL_VIEW_GROUPS        ,
  RL_VIEW_PONDERATION   ,
  RL_VIEW_REINFORCEMENT ,
  RL_VIEW_ELEMENTSFINITE,
  RL_VIEW_PANELS,
  RL_VIEW_EF_DATA,
  RL_VIEW_GLOBAL_MB,
  RL_VIEW_GLOBAL_EF,
  RL_VIEW_DETAIL,
  RL_VIEW_PROPERTIES_PANELS,
  RL_VIEW_MEASURE_PANELS,
  RL_VIEW_RDIM,
  RL_VIEW_PROPERTIES_CABLES,
  RL_VIEW_PROPERTIES_JARRETS,
  RL_VIEW_OFFSETS,
  RL_VIEW_SUPPORTS_LABEL, //independent
  RL_VIEW_LIARIG_LABEL,   //independent
  RL_VIEW_MOBIL_LINE,     // TJ mobil
  RL_VIEW_BEST,
  RL_VIEW_ESTIM,
  RL_VIEW_CUTS,
  RL_VIEW_TEMP_LINE,
  RL_VIEW_PANEL_RR,
  RL_VIEW_PROPERTIES_VOLUME,
  RL_VIEW_SOLIDS,
  RL_VIEW_SOLIDS_FE,
  RL_VIEW_SOLIDRESULTS,
  RL_VIEW_PUSHOVER_LINE,
  RL_VIEW_CURVE_LINE,
  RL_VIEW_ADVANCED_LINE,
  RL_VIEW_IMPERFECTIONS,
  RL_VIEW_VOLCUT,
  RL_VIEW_ELAPLA,
  RL_VIEW_PROPERTIES_MATERIAL,
  RL_VIEW_GROUPS_VAL,
  RL_VIEW_GROUPS_NODE,
  RL_VIEW_GROUPS_OBJ,
  RL_VIEW_GROUPS_ES,
  RL_VIEW_GROUPS_LOA,
  RL_VIEW_LOADS_EDIT_TEXT,
  RL_VIEW_STOREY,
  RL_VIEW_MEASURE_SURF,
  RL_VIEW_MEASURE_VOL,
  RL_VIEW_MASSES_CONV,
  RL_VIEW_EF_PANEL,
  RL_VIEW_STOREY_FRED,
  RL_VIEW_FINT,
  RL_VIEW_FOC,
  RL_VIEW_FOC_LINE,
  RL_VIEW_FF,
  RL_VIEW_FF_LINE,
  RL_VIEW_LOADS_NOTIONAL,
  RL_VIEW_CORWALLS,
  RL_VIEW_STOREY_DEPL,
  RL_VIEW_END
Rafal Gaweda
Romanich
In the Robot 2015 issues from the first topic still exist. I tried to solve p.2 by the API but have found some bugs (or maybe it was features 😉
Method AddColumn() accept integer data type. But I have not found any info about it (do you have this list with column internal numbers?) Maybe it will be useful if enumerator will be implemented instead of numbers.
Also this situation should be fixed:
.AddColumn(-100); //any negative number
  return:
Moreover, I think the internal check in Robot should be implemented - if column exist on the current table, user can't add the same one:
 for (int i = 0; i < 5; i++)
                tableReaction.AddColumn(25);
It will be a great, if in the next version will be implemented methods like DelColumn()(to delete unnecessary columns), MoveColumn() (to simulate drag drop by user).
Roman Zhelezniak
Tags (1)
Rafal.Gaweda
I will register DelColumn on whishlist for implementation
I will register need for table columns list with description or creating enums on whishlist for implementation.
Rafal Gaweda
Romanich
in reply to: Rafal.Gaweda
In the Robot 2016 issues from the first topic still exist.
Roman Zhelezniak
