Please find below list of some bugs in RSA 2014 that was found:
1- When you open a file and then Save As another name, after you do your modifications and close, it will ask to save the changes to the original file and not the new file.
2- Robot command line does not work properly in RSA2014, I used to be able to insert load combinations into file where loads (CAse) were already defined, but now RSA will freeze if I try to insert load combinations for already defined loads.
3- Robot command line does not work properly in RSA2014 when I try to insert loads and load combinations, for some reason the loads will be assigned to elements other than assigned in the text command with some errors while excuting the command.
Please check http://forums.autodesk.com/t5/Autodesk-Robot-Structural/RSA-2014-Word-2007-report-and-saving/td-p/39...
Rafal, The issue was solved when I updated with the new service pack for point #2, but still not all the loads assigned properly when I assign loads through command line.
Rafal,
I just realised that the files were not sent with the last post, I am not sure if there is an issue with the website or with my internet explorer.
please find Re 3 in this link:
http://www.4shared.com/zip/fPJRtOXm/RE-3.html
Re 2 in this link:
http://www.4shared.com/zip/Kn1RTSrt/RE-2.html
so as said before, Re2 was solved after I updated RSA with SP2 while still if I write a text file and import it the loads are not assigned properly to the specific members/elements. I tried appling the loads into the model and back save it to text file then deleted all the loads in the file and then re-assigned it using the command line, still having the same problem.
