Discussion Groups
Robot Structural Analysis
*Expert Elite* | International Moderator
Romanich
RSA 2014: Automatic verification
593 Views, 11 Replies
07-13-2013 06:21 AM
Is it possible to switch off automatic verification in RSA 2014? Maybe some changes in INI files and etc? Because this was a timesaver trick for advanced users.
2014:
2013:
Please use plain text.
Product Support
Artur.Kosakowski
Re: RSA 2014: Automatic verification
07-15-2013 12:26 AM in reply to: Romanich
I fully understand your point but this change is intentional to prevent situations where incorrect models are calculated with no information about this fact whatsoever especially when they are sent for cloud computing.
Artur Kosakowski
Romanich
07-15-2013 01:00 AM in reply to: Romanich
It seems that the cloud spoil the Robot...
Product Support
Artur.Kosakowski
07-15-2013 02:40 AM in reply to: Romanich
That is not that simple. On one hand there are requests from users as you I know what 'm doing and I don't need these 'unnecessary' checks as they slow me down and the same time you have comments like the program should never calculate structure that is incorrect without giving me a warning. At the end of the day the development team has to make some decisions :smileyhappy:
Artur Kosakowski
Romanich
07-24-2013 06:30 PM in reply to: Romanich
Dear Artur, do you have information from the development team?
Romanich
10-11-2013 05:56 AM in reply to: Artur.Kosakowski
Trying to solve this issue using API
Sub CalculationStart()
Dim Robapp As IRobotApplication
Set Robapp = New RobotApplication
Robapp.Project.CalcEngine.UseStatusWindow = True
Robapp.Project.CalcEngine.AutoGenerateModel = False
Robapp.Project.CalcEngine.AnalysisParams.AutoVerification = I_SAVT_NONE
Robapp.Project.CalcEngine.Calculate
Set Robapp = Nothing
End Sub
 As result information about verification is missing also in robwin.log:
Product Support
Artur.Kosakowski
10-21-2013 04:32 AM in reply to: Romanich
After installing SP3 for Robot 2014 create a new registry:
HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\27.0\Settings\StructureVerificationOFF with the value 0
Artur Kosakowski
Romanich
10-21-2013 07:55 AM in reply to: Artur.Kosakowski
Thank you, Artur. Could you look at the reg file?
Product Support
Artur.Kosakowski
10-22-2013 02:56 AM in reply to: Romanich
Artur Kosakowski
Romanich
10-24-2013 04:53 PM in reply to: Artur.Kosakowski
Thank you, Artur!
For all Robot users - you can find two reg files to quick on/off Automatic Verification in the attachment.
P.S. Don't forget to restart Robot.
