Is it possible to switch off automatic verification in RSA 2014? Maybe some changes in INI files and etc? Because this was a timesaver trick for advanced users.
2014:
2013:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
Solved by Romanich. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
I fully understand your point but this change is intentional to prevent situations where incorrect models are calculated with no information about this fact whatsoever especially when they are sent for cloud computing.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Roman Zhelezniak
That is not that simple. On one hand there are requests from users as you I know what 'm doing and I don't need these 'unnecessary' checks as they slow me down and the same time you have comments like the program should never calculate structure that is incorrect without giving me a warning. At the end of the day the development team has to make some decisions
Roman Zhelezniak
Trying to solve this issue using API
Sub CalculationStart() Dim Robapp As IRobotApplication Set Robapp = New RobotApplication Robapp.Project.CalcEngine.UseStatusWindow = True Robapp.Project.CalcEngine.AutoGenerateModel = False Robapp.Project.CalcEngine.AnalysisParams.AutoVerification = I_SAVT_NONE Robapp.Project.CalcEngine.Calculate Set Robapp = Nothing End Sub
As result information about verification is missing also in robwin.log:
Roman Zhelezniak
Dear Artur, do you have information from the development team?
After installing SP3 for Robot 2014 create a new registry:
HKEY_CURRENT_USER\Software\Autodesk\Structural\RSA\27.0\Settings\StructureVerificationOFF with the value 0
Thank you, Artur. Could you look at the reg file?
Roman Zhelezniak
Thank you, Artur!
For all Robot users - you can find two reg files to quick on/off Automatic Verification in the attachment.
P.S. Don't forget to restart Robot.
Roman Zhelezniak
Hi Tony,
I think that user must know about the verification itself and such modification that is doing for own risk.
Roman Zhelezniak
