I started using the software recently and when activating the nodes and structural axis definitions I'm running into display issues: the nodes don't appear even when the display of them is activated, and the contents of the structural axis definitions don't display but the bubbles and structural axis do display.
It is a really bothersome problem as this display functionality helps when navigating the projects I'm working on, I already tried repairing the installation, and uninstalling and installing the software.
I'm using a 32 bit version of RSA 2011 on a 64bit Windows OS and using a student licence.
Solved by Francois.Augiere. Go to Solution.
- Go in Tools, Preferences, Desktop Settings
- In "Range" list, choose Fonts
- In "Element" list, Choose Node numbers
- Click on Font button
- Change from "Arial" font to something else (as shown in attached screen capture)
- Ok and Accept
If now node numbers are visible, do the same for "Structure axis numbering" (in "Element" list when Fonts is selected for "Range" list)
You may have a problem with Arial font in your version of Windows ...
