I am trying to create a routine to create, trough API, a member type definition to Steel Design where I can define the intermediate bracings positions. I developed a code, it chooses the correct option but ir does not writes the bracings positions and does not activates that option. Can anyone tell me what I am doing wrong?
Thanks...
Dim MTdata As IRDimMembDefData
Dim MTpar As IRDimMembParamsE32
Dim Ptos As IRDimMembDefIntPsDataType
Set LABEL = METALICA.Project.Structure.Labels.Create(I_LT_MEMBER_TYPE, "COLUMNS_1")
Set MTdata = LABEL.Data
Set MTpar = MTdata.CodeParams
MTpar.BuckLengthCoeffY = 10
MTpar.BucklingDiagramY = I_DBD_E32_INTERNAL_BRACINGS
MTpar.BracedY = False 'Not Sway
MTdata.SetIntPsCoordValueType I_DMDIPDT_BUCKLING_Y, True
MTdata.SetIntPtAddOption I_DMDIPDT_BUCKLING_Y, I_DMDIPOT_MANUAL_COORDS, 0
MTdata.SetIntPtValues I_DMDIPDT_BUCKLING_Y, 1, 0, 1
MTdata.CodeParams = MTpar
METALICA.Project.Structure.Labels.Store LABEL
I have exactly the same problem as @Anonymous, with exactly the same script.
You said, in your last message, that the problem was Corrected with RSA 2015 SP1 and I have RSA 2018.
Can you help me ?
regards,
Hi @xblanchet
I ma very sorry, You are right. The issue is back.
It worked well in 2015SP1 and 2016.
Need to be fixed again.
Thank You for reporting it.
