Hi everyone!
I recently discovered ROBOT API and I need some help for several things in my macros:
1/ I would like to know the commands to add nodal masses. I found out in the Robot API Tutorial how to create and set cases and loads but i couldn't find how to generate masses automatically, as if I was using the "Added Masses - Weights" table directly in the software.
2/ I'm trying to find a way to modify the factor value of a self-weight load (to change it from 1 to 0,5 for example) but i coudn't find how anywhere in the forum nor the tutorial. Moreover, I don't how to set the list of elements to "Whole structure" and i'm forced to cheat by saying for example "1to100", if I know that my structure will have less than 100 elements. Here is my code so far:
''Définition des chargements accidentels sur toute la structure For k = 3 To 5 Set cas = robapp.Project.Structure.Cases.Get(k) cas.Records.New I_LRT_DEAD Set rec = cas.Records.Get(1) rec.Objects.FromText "1to100" Select Case k Case Is = 3 rec.SetValue I_BDRV_X, 1 Case Is = 4 rec.SetValue I_BDRV_Y, 1 Case Is = 5 rec.SetValue I_BDRV_Z, 1 End Select Next
The "1" argiment in "rec.SetValue I_BRDV_X,1" command is only to define if the load is in the same direction as X axis or in the other one. I couldn't managed to change the factor of the load.
Could someone help me with those issues? I don't know if I'm being clear enough but i could give more informations if needed.
Thanks a lot in advance!!
Gabin
Dim SCase As RobotSimpleCase ...... Set RecordNew = SCase.Records.Create(I_LRT_DEAD) RecordNew.SetValue I_DRV_COEFF, 0.6 RecordNew.SetValue I_DRV_ENTIRE_STRUCTURE, 1 RecordNew.SetValue I_DRV_Z, -1
Try harder.
for example in this macro: http://forums.autodesk.com/t5/Robot-Structural-Analysis/API-Exporting-modal-harmonic-load-case-getti...
RSelection.FromText "all" 'for english robot RSelection.FromText "tous" 'french RSelection.FromText "wsz" ' polish , and so on
1/ I would like to know the commands to add nodal masses. I found out in the Robot API Tutorial how to create and set cases and loads but i couldn't find how to generate masses automatically,HINT: load to mass conversion is stored as case = -1
Unfortunately not complete load to mass conversion record can be generated by API. Hope it will be implemented soon.
This is all you can set\get now:
Dim cas As RobotSimpleCase Dim rec As RobotLoadRecord Set cas = robapp.Project.Structure.Cases.Get(-1) Set rec = cas.Records.Create(I_LRT_MASS_ACTIVATION) rec.SetValue I_MARV_FACTOR, 0.7 rec.SetValue I_MARV_CASE_NUM, 3 rec.SetValue I_MARV_ACTIVATION_DIR, 2 rec.SetValue I_MARV_SIGN, 1
HINT for code below: SCase must be Modal case
Set RecordNew = SCase.Records.Create(I_LRT_NODE_FORCE_MASS) RecordNew.SetValue I_NFRV_FZ, 10 RecordNew.Objects.FromText "1"
