Discussion Groups
Robot Structural Analysis
Active Member
Robot12
RESULTS - DISPLACEMENT vs. DEFLECTION - Definitions used by Robot
2182 Views, 5 Replies
06-18-2012 01:00 PM
What are the definitions for deflection and displacement used in Autodesk Robot Structural Analysis ?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Definitions used by Autodesk Robot Structural Analysis
06-19-2012 12:09 AM in reply to: Robot12
Which kind of results do you mean exactly? Could you make a screen capture that illustrates what you want to compare please?
Artur Kosakowski
Active Member
Robot12
06-19-2012 03:00 AM in reply to: Artur.Kosakowski
I don't want to compare any results I just want to know what are the differences between deflection and displacement ? I want definitions for both deflection and displacement used by Autodesk Robot Structural Analysis.
Thanks.
Product Support
Artur.Kosakowski
06-19-2012 03:16 AM in reply to: Robot12
Artur Kosakowski
Active Member
Robot12
06-19-2012 04:39 AM in reply to: Artur.Kosakowski
Does this illustration of deflection and displacement apply to a 3D frame ? Is there any sentence that defines deflection and displacement ?
Thanks.
Product Support
Artur.Kosakowski
06-19-2012 04:44 AM in reply to: Robot12
Yes, it does. The displacements is the distance from the original position of a point to its final location on the deformed model. The deflection is the distance from the line that links the origin and end nodes of a bar on the deformed model with the position of a point on the deformed model.
Artur Kosakowski
