I'm designing RC column by using robot based on ACI-code.Also the automatic combination for the structure model are generated based on the same code.However I noticed that after viewing the colum design notes that the design combination is different from the automatic combinations. Can you explain thisplease.
Could you attach the corresponding rtd file and indicate the difference in combinations on a screen capture please?
