I can't define materials and reinforcement parametres for RC beam.(see attached picture) Please, suggest what I have to do. Thank you.
Have you assigned code check parameters to the beam yet? Not sure if this is going to make a difference.
I just checked it makes no difference.
Maybe reset default RC code, close Robot and reopen?
Yes, but it doesn't work with new SP 63.13330.2012.
Only with old SNiP 2.03.01-84. Do you know where can I find the list of codes available in RSA to design different elements(as I understood i can design rc slab according to new russian code, but i can't design rc beam according to this code)
you can normally see in the Readme files for each service pack if new codes are implemented. eg
http://images.autodesk.com/adsk/files/RSA2014_SP2_readme.htm#R/C_Members_Design_SP_
but i don't know if there is a list of RC codes as such. I have the same "problem " in Australia. Only required reo is available, not design for provided reo.
BS8110 is pretty good in Robot...........
This code is implemented for required reifnorcement for bars and panels. Not provided \ full modules.
"c:\ProgramData\Autodesk\Structural\Common Data\2014\Data\Other\norms.xls"
Just a list, not range of implementation
