Hello, I'm trying to design this wall with a surface pressure (water, is for design a concrete tank), everything is fine on the results, moments, displacements, stress, but when I'm going to run the RC reinforcement and I choose Manual combinations, the program crashed.
I proved with automatics combinations acording with the ACI318 code and I got the same error message.
Hello, of course, this is the file. And I have the same problem with all the projects when I choose manual combinations.
Look, I can't upload the file here, the file does not have a valid extension for an attachment (doc,pdf,dwf,dwg,dxf,dst,gz,gzip,zip,bm,bmp,gif,jfif,jpe, jpeg,jpg,psd,tif,tiff,png,xml,xls,lsp,svf,3ds,vcf,png, text,txt,log,env,dcl,rvt,rfa,ipt,iam,ipn,dwfx,idw,csv,nwf,nwc,nwd,sdf,cfz,vtfx,vtf,pat,f3d are the valid extensions.)
I uploaded the file to my dropbox https://www.dropbox.com/s/hscgil7y4lui1ks/wall.rtd
You can zip it and then attach directly.
I can't see any problems with exporting the wall with defined ULS combination to the RC Wall design module. Please try to delete the temporary windows files and check again. If that doesn't help send the crash report and tell me what email address you entered so that I can find it.
On the other hand as your load causes out of the wall plane bending IMHO the design of this panel as a shear wall may not be what you really need. Personally I would design reinforcement using the RC Slab Required Reinforcement module instead.
I choose panel like you said and the problem remains.
The email on the report is bartolome1819@hotmail.com
Thank you for your time
The development team has decided to deliver a fix in Robot 2015. Please note: Our quality assurance teams may need to reschedule some fixes. Please rely on the above timeline information as a guideline only and not a guarantee. We appreciate your understanding in this matter.
