Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
RC Wall - Option for provided reinforcement not implemented yet
3 REPLIES 3
1969 Views, 3 Replies
Im trying to reinforce some concrete walls with RSA 2013, according to NS-EN 1992-1-1:2004/NA:2008
(National annex for Norway)
After I run calculations for required reinforcement, I try to got o provided reinforcement, (to provide the reinforcment) and then do the verification. We have done this before without any problems (of this kind), using RSA 2011.
When I try to go to provided reinforcement i get an error message saying "RC walls - NS-EN 1992-1-1:2004/NA:2008 - Option not implemented yet"
If I change the definition of "structure object" for the wall form "wall" to "panel" Im able to calculate required reinforcement, and do the provided reinforcement.
Is this an acceptable workaround?
Does Robot do verification for a wall different from a panel?
3 REPLIES 3
Artur.Kosakowski
Try to set the design code to NF EN to compare both approaches.
Artur Kosakowski
Thanks, it solved that problem.
Btw., where is that "Accept as Solution button" button?
AJA
AhmedZA
in reply to: Svarthamar
