I have to calculate 28 RC foundations. So, my question is,....Is it possible to set dimensions and soil properties in the RC Foundation module for all of them at once or should I set it one by one.
Regards!
Yes, it is possible. Select all 28 supports and then press Provided reinforcement button. The design of foundation will be with forces from 28 supports one by one.
Ok,...thank you!
but when I enter the Provided reinforcement module,....I want to set all the RC dimensions 70/70/50cm.....and soil properties all the same value???
the only way to do it is to pick one by one??? Am I wrong???
Regards!
How? if you have 28 different footings.
Save soli pattern and load it to each foundation
when you create a group, you can set dimensions and soil properties to all foundations at once.You don't nedd to pick them one by one:
Hi Rafal,..
I want all my foundations to be the same (for example 70/70/50cm)!!! The construction workers wouldn't be happy if I came with 28 different foundations 🙂 !!!
How can I save the soil pattern!
Thanks jivkomitev2!!!
That's what I wanted,....how to create a group?
Regards!
In model space select all 28 jonts (supports) and then press Provided reinforcement button
Look at your screen shot - that's why I asked?
In fact use jivkomitev2 hint.
