Message 1 of 11
tony.ridley
617 Views, 10 Replies
RC Design Isues
Hi guys,
Having a bit of a shocker today with the revit link;
When I change the reinforcing bar database to AS3600, the link will not update reinforcement into the footings in Revit.  It was working for ACI bars.
So if I use AS3600 bars, it throws an exception (i've attached a txt file with the exception text).  Also attached the Robot file.  Using Robot and Revit 2013.
Cheers,
Tony
10 REPLIES 10
Message 2 of 11
Rafal.Gaweda
in reply to: tony.ridley
Thx for reporting
Rafal Gaweda
Message 3 of 11
Tony,
Are you doing RC design to AS3600 in Robot 2013??
Rgds,
Rich
Message 4 of 11
No, not implemented yet.
In the original post i was referring to some RC design I did with various other codes using Australian rebar, then importing into Revit.
Have you done any?  if so, how? Smiley Happy
Tony
Message 5 of 11
Tony,
No unfortunately not...I was hoping that you had found a way with something that I had missed. This update has been a long time coming.
Rgds,
Rich
Richard Whitfield
Structural Engineer
Mott MacDonald
Level 2, 60 Pacific Highway, St Leonards NSW 2065 Australia
PO Box 151, St Leonards NSW 1590
www.mottmac.com.au
T +61 (0)2 9439 2633? |? F +61 (0)2 9438 4505?
E richard.whitfield@mottmac.com
Mott MacDonald - Confidential Communication. This e-mail is confidential. If you are not the intended recipient, or you have received this e-mail in error, any use, dissemination, or copying is prohibited. Please destroy this transmission (including any attachments), and notify the sender by reply e-mail. Mott MacDonald takes care to ensure that data transmitted is appropriate and that the content is free from viruses or defects. However, we do not warrant that this communication is free from any viruses or defects. We deny any liability for loss or damage caused as a result of the receipt or use of this communication.
Message 6 of 11
HInt:
Rafal Gaweda
Message 7 of 11
tony.ridley
in reply to: Rafal.Gaweda
Rafal,
Thanks, but I don't 100% agree.
It seems that we have been given required reinforcement check for slabs and beams only?  Not columns.
And no check for provided reinforcement, only required.
It's better then nothing I guess, but still not perfect Smiley Happy
Tony
Message 8 of 11
We are downloading now, I'll throw my 2 cents work in when I've had a play.
Message 9 of 11
Rafal.Gaweda
Yes, only theoretical reinforcement
If you want more : http://forums.autodesk.com/t5/Robot-Structural-Analysis/idb-p/93
Rafal Gaweda
Message 10 of 11
tony.ridley
Message 11 of 11
Rafal.Gaweda
more votes 😉
Rafal Gaweda
